- Lake Orion, MI
Been a long time since I've done a build thread on here. Always wanted one but was finally able to acquire a Carbon SF Circus. My DVX will remain my flatwater freestyle machine, so the plan is for this to be a backup ski / casual lake ripper and maybe a great lakes surf boat with a different ride plate. Picked this hull up from @zeski25 and it has exceeded my expectations. Paint is awesome and was sent with a bunch of extra hardware motor mounts etc. Also has an immaculate turf job! Freestyle Connection for the win!
HULL & BODY:
ENGINE:
PUMP:
Enjoy the build and pics, will try to document as I go
HULL & BODY:
- Carbon Circus Hull & Hood
- RRP Billet Lightweight Pole w/Carbon Tubes cut to 14"
- ADA Steering System
- RRP Ninja Holds (Not Adjustable)
- OEM Hood Latch & Thurst Front Hood Hook
ENGINE:
- Yamaha 760cc w/Cylinder Porting (Will do case porting when it arrives)
- Stock Electronics w/MSD Enhancer & Lightened Flywheel (Hopefully upgrade to Zeel System in the long run)
- PFP Exhaust
- Stock 44mm Carbs
- PHP Intake w/VForce 3 Reed System
PUMP:
- OEM 155
- 6/12 Cutback prop per recommendation from multiple sources to start
- XS Gen 1 Trim System
- Stubby Cone
