I had a Vilder on a Limited SJ and it was very nice....... until it died. But, that may he been self inflicted, who knows. For a limited to mild set up, they are nice, but in NO WAY can they compare to the power you get with a properly set up MSD TL. And the stock Yamaha may be rated up to 20,000 volts, but I can garrantee you that it never actually gets to that point. Do a spark check on a stock based ignition, then do the same with a MSD TL system and you can visually see the difference. And make SURE you aren't touching anything connected to it! (right Kawi66!!!) We learned that one the hard way.
Also, you can go to the MSD site and plug in what timing specs you want to run and they have a calculator that will tell you how to set the box up for that timing.
I have ridden skis with advents, advents with lighten flywheels, Vilders, vilders with vilder flywheels and none of them have the "hit" that the MSD has. MSD might not be the most user friendly of the group, but in terms of power, it is pretty much the top dog. Especially if you have John @ Jetski Solutions set it up - (SHAMELESS plug for one of my sponsors!!!!)
Scott
