Need help with 760 compression
I recently bought a superjet so here is what it has. 62t case 64x topend, b pipe. I just switched to duel 38’s from duel 44’s and I just put a new ADA head with 38cc domes.
I just checked compression and I have 175 in the front and 145 in the back. The pistons and sleeves look really clean.
I am stumped on how my compression is so different. Anyone have any ideas on what I can look into to get them even?
dfw
Either you have a damaged bore/stuck ring or the ADA head isn't sealing. Its easy to tell by the pisser stream. Steady= no leak, broken=head not sealing to cylinder. BTW Yamahas can be difficult to seal without a gasket. Sometimes you have to resurface the deck and shim the domes.
maxboost
Super tuned
Ia
Make sure you got the same domes, I’d measure them. Seems like I recall couple people saying they were marked wrong in the past
If you cant measure the domes, switch them front to back and if the low compression follows the dome you know you either have a differnt cc dome or that dome is not sealing to the deck.
Stockton
Pull the head and check the oring on the dome, prolly slipped out... needs to be installed with grease in the grove and on oring to help it stay put while installing it
