Superjet starter shenanigans
Hello, I am the unfortunate new owner of a 2001 superjet. Apparently this ski was reliable as hell and it even started in the guys garage I bought from, but as soon as I got is home it was apparent that the ski was electrically fried.
Replaced teh start/stop lead in the ebox, replaced every 4 gauge cable, fixxed all the broken wires in the ebox. Still wont crank, so out comes the starter motor and it just throws sparks on the bench. I can't find a single Mitsuba trademark on this thing so I assume it is aftermarket crap, but apparently this motor worked for over a decade somehow.
It looks fine and I even tested the armature, everything seems to be dialed. I don't know if its worth reassembling though as something is obviously not right.
Now I have a used mitsuba Sm-13 on order, it looks clean as hell, no rust. i'm trying to find a rebuild kit for it, and I found this http://www.stockers.com/index.php?dt=SM-13
What sucks is it appears to just be the brush holder and brushes, doesnt even picture the pos post o_O
Is there anywhere to get a complete rebuild for the OEM starter anymore? Does anyone know of a kit that crosses over from like an ATV starter?
Last question, is the Sm-13, which I believe it the stock superjet starter, is it a 4 pole or a 2 pole motor?
Thanks for the help, Im not usually so wordy but I have been tearing my hair out over this thing. I don't even care if I ever get this thing in the water, I just want it to start 1 time in my garage.
That's an a/m kit. Suggest you wait til you receive the used Mitsuba you ordered. If it looked really good on the outside in the pics, It might be a good one. Take off the tail end, make sure the brushes have at least 60% life left and are not stuck. Pull off frnt. cover and make sure no "fretting" is visible on the armature shaft ( caused by a worn needle bearing). It would help to put bearing grease on the needle bearing, the rear bushing will likely be very dry. It is/ should be an oil lite bushing- which means it can absorb some lubricant and retain it. Careful here! just a wee bit grease! The grease has a nasty habit of finding it's way to the brushes and softening them- maybe that's why that bushing is pretty dry on a new one.- You prob. wont need that a/m kit!
Stockton
I’ll add, first bench test the used one when you receive it, to make sure it spins......Before doing any work on it..
Just thinking of the transaction between buyer and seller...
bored&stroked
Urban redneck
AZ
When I was a service writer we had brand new never ran superjets go bad on the sales floor and not start when they were getting prep'd for delivery.
