Blue
Judging your cheapness
- St Cloud Florida
Carbon Havoc Freestyle Hull
Motor and Electrics are sold.
Would like to sell the Hull complete minus engine and electrics for $7000 But may separate for quicker sale.
Havoc Hull with title, 155 aluminum pump shoe, Thrust steering with Fat bars and Trigger. X-Metal Adjustable Pole, Rebuilt Mid Shaft, Scoop Grate, Cables, Motor Mounts, hood ratchet strap kit, 500 gph bilge, rotary switch, primer, dual scuppers. $5000
Limited slip 5 gallon tank, $350
Like New Ported B-pipe with dual cooling, adjustable flow control valve, Jetmanic water box and 45 degree silicone hose. $1200
Oem 155 pump rebuilt with new driveshaft, new bearing, seals, new wear ring Skat 6/12 setback prop, Nozzle has oem tilt ring that could be used as a trim system. $600 complete.
Im sure i forg
Sent from my SM-N950U using Tapatalk
Im sure i forg
