Super Jet WTF? Headpipe pisser not pissing
SXIPro
JM781 Big Bore
@ Jetmaniac 781BB factory B pipe dual cooling. I am getting no water out of the cooling line that comes out of the top of the head pipe. If I blow into it while the ski is in the water I can hear bubbles. If I suck on it, I can pull water thru. If I hook it back up and run it I get zero water coming out of the fitting from the top of the head pipe. Both fittings from the head and the associated pissers flow like a dream. This did start after I was in some pretty murky water. But if it were clogged, why would I be able to blow thru it and suck water thru it?
Jcary85
Glenmoore pa
Sometimes wasps and such will build a small mud nest for a larva inside of a pisser. Everything else flows fine but nothing comes out.
Just had that exact thing happen to all 3 pissers a few weeks ago. After only a few days of not riding. Nasty scraping that stuff out
