How permanent is that stuff? Looks like it's similar properties to the 1211. The bolts hold everything in place so you don't need anything that has adhesive power, just filling in the gaps between the 2 cases. Don't put any on the shaft part with the o-rings. Just a bead around the starter case that makes contact with the flat part of the engine case.
