- Sliedrecht
Hello,
Recently i fell of my jetski and i wanted to start it back up, but nothing happened, like, really nothing happened. Checken the lanyard switch, batt connection etc etc but nothing worked. Then i bought a new battery and everything worked OK. I thought , o well battery went bad.. Couple days ago the same happened. Fell of, try to start again and nothing happened!! Didnt click, turn over etc. So i checkd the battery voltage while running (with a 3rd battery) and it stays at 12.7V, same as when the ski is off. Opened the e box, bit of corrosion here and there, but nothing looking off.
I measured the résistance between the 2 green wires that comes from the flywheel and the resistance was 1.2 Ohm. The résistancebrtween the 2 wires going into the voltageregulator is 24 MEGA Ohm. Are those numbers as they should be? And why is my battery not charging? Busted voltage regulator? Or could it be something with the flywheel magneto? I read something about a pulsar, lighting coil? Are those the coils inside the ebox? Or are they in the flywheel area?
Thanks!
Thanks!
