- Central PA
So I just got a 93 650 sj for a good deal, that catch was that it has some issues. I have a few questions that I would appreciate if someone would be kind enough to answer.
-My midshaft bearing has a decent amount of play in it. I did some reading on other posts but no definitive answer. Is this normal? If not, how hard is it to press out and press in a new bearing? I come from an 1100zxi where the bearing comes in a rubber plate that breaks and fills the hull with water. This looks a little nicer to deal with as the bearing just seems sealed to the midshaft housing and the housing sealed to the hull.
-I have been looking at SOLAS YB-IG-B intake grates (as mine is broken) but I am getting different answers from different ebay vendors as to that if it will fit my 650. Some vendors have them listed as 94+ 701 skis and some have the 650s listed as well. Will the SOLAS YB-IG-B fit my 650sn?
-I found the reason my ski didn’t want to turn over was a stator cover filled with water that froze the starter. I will replace the gasket but is there anywhere else for water to get in there besides the starter oring, stator wires, and gasket?
-The exhaust hose coming off my waterbox is severely deformed, is this normal for clearance? I imagine not. Does anyone know a method that I can use to try to get it back to its original shape? (see pics)
-My "hydroturf" is peeling off due to the adhesive coming off. If I take the "hydroturf" off and remove the old adhesive is there a commonly known marine adhesive that I can spray on to make it stick again?
-I found two random rubber pieces in the hull when taking everything out. Does anyone know where they go? (see pics)
Thanks!
Thanks!
