Your pole should have come with 2 sets of bushings. Did you use the SJ ones or SXR? Also. Slightly bevel the outer edge. This will let the bushings slide in. Or remove bracket and loose ears. Do not use a clamp to squeeze anything to fit.
Little bit of weight without moving. Should stay put......I use a large breaker bar or a wrench with a cheater wrench on the first wrench to crank the bolt down. Then tighten the nut uo...
I switched to stainless bolt I was cranking it down so tight... my other skis poll has aluminum RRP bolt.... not risen it yet but it’s still too loose.... have to tighten more.. hard to lift poll but goes down too easy...
On the poll bracket uprights did you loosen all the on each side ?
Yea I was a little worried about cranking it down too much. But good to know. Mine is deff harder to lift than to push down. So probably need to go tighter.
On the pole bracket, I did loosen all of the bolts then installed the pole, got the bolt started and then tightened all of the bracket bolts. I will deff put red loctite on the bracket bolts when I do the final assembly. Why do you ask though?
Did you mock up your pump with the shoe?
Did you use Plexus on shoe ?Got the hood prongs and latch installed. The paper method worked great for locating all the spots where the seal wasnt tight enough.View attachment 396768View attachment 396769
After several days of grinding away at that pump shoe, I think this is about as good as its gonna get. Then i finished removing the remaining gelcoat and double checked everything was square. Got the gap to 0.050" +/- 0.005.
View attachment 396771View attachment 396772View attachment 396773
Pump shoe is finally glued in! So happy to be done with this part of the build!!
View attachment 396774View attachment 396775View attachment 396776
What's the deal with the coupler spacers that came with the hull? Is it recommended to use both or just one or what?
Up to you. They're good for moving the motor forward if you have the rear tank, or need it to get your pipe more forward. It also helps with weight distribution if you want more weight in the front, should help with more height, but slower rotations.
