- Asheville, NC
I sent my pipe to Jet-Hot for a ceramic coating and I’m finally getting everything in place and finishing up my build. I reinforced the hull on my 1995 Yamaha Superjet and of course filled the bond line with epoxy. I used 2 layers of 1708 biax with backer. Now with my engine in place and trying to fit the pipe, I’m having major clearance issues. I’ve already ground out such a groove that I’ve run into the factory glass on the bottom hull. I’m not even close to fitting... do I need to grind all this epoxy out to get my pipe to fit? This blows.
