46mm Novi Carbs
CA
Hello,
Cleaning out parts bin...
  • 46mm Carbs, I believe these are Novi D boosters with spigot mount. I ran these last season on my JM Big Bore and they ripped with a reducer jet in the return line.
They need to be rebuilt, and you'll need needle/seat/jets. They require an external fuel pump as configured. One of the purple block bolt holes (the one without a screw) is stripped, you can tap bigger or time sert and it should be an easy fix.​
$250 shipped OBO.​
  • SOLD H20 designs billet battery box, adjustable. $60 shipped
  • SOLD H20 designs 3 gallon tank with custom strap hooks. $140 local pickup (Bay area, CA) or $160 shipped
  • SOLD Epic billet couplers for square nose midshaft. The mid shaft side will not fit a RN midshaft! $40 shipped
CA
These carbs are for Yamaha btw, I ran them on a stock 44 intake and had noticeable gains over the OEM 44's.
Can include intake if you need it for just a little extra shipping cost
Sent from my SM-G975U using Tapatalk
DirtTOwater96
Pre_mix.. addicted
Illinois
Hello,
  • Epic billet couplers for square nose midshaft. The mid shaft side will not fit a RN midshaft! $40 shipped
  • 46mm Carbs, I believe these are Novi D boosters with spigot mount. I ran these last season and they ripped with a reducer jet in the return line but i took them off chasing issues, turns out my motor was blown...I'm all tuned in on my 44's and i don't want to go through tuning again.
They need to be rebuilt, and you'll need need/seat/jets. They require an external fuel pump as configured. One of the purple block bolt holes (the one without a screw) is stripped, you can tap bigger or time sert and it should be an easy fix.​
$275 shipped OBO.​
Messaged you I’ll take the billet couplers
