- Greece
bought a +10 year abandoned 92 SN recently.
removed the pump and looks like corrosion has done its job
The impeller is literally stuck against the wear ring and doesn't move a mm (tried also with a wrench)
Question 1: best way to take them apart without too much further damage ?
Question 2: I know nothing about jetski impellers, can anyone tell me by looking at picture if this prop is Aluminium or Stainless Steel ?
I have read that SS propellers can be re-welded/ filled up edges and re balanced.... what about Aluminium ? can they be repaired / rescued ?
Finally is the liner on those wear rings replaceable? i've read that sanding slightly down is a temporary solution an swelling will reoccur fast.
any jet pump experts out there ?
