Choke removal
Jlg
Uk
I’ve removed my chokes to fit a primer but now it has a bog on the low end but runs fine on the top end what needs done
Jlg
Uk
I’ve tried that and it’s not much better but I’ve been told that the proper way is to change the pop of bug Idk
Jlg
Uk
Posting your Engine Specs and Pics would be helpful.: Engine cc, Carb size, Pipe, etc
Did you also install Flame Arrestors along with the Primer? If so, that will require a lower Pop-Off to match the decreased Pulse Signal.
But all you said was that a Primer was installed...
Bone stock 2001 701 superjet only thing done is fit a primer as I had the engine out
