Anyone know the length of the Superjet Start/Stop harness?
Req
SW Tenn
Im taking my ebox and SS switch down to be changed to the stand up lengths at the local respected electrician in a couple of hours. For the Start stop side what is the length? Additionally what is the length on the tail coming out of the ebox?
thanks a bunch for the help!
Roseand
The Weaponizer
Wisconsin
Start stop side: approximately 95 inches from the outside of the grommet to the tip of the black connector and 99 inches for the white connector.
Ebox side is about 7 inches from the outside of the grommet to the tip of the black connector and 6 inches for the white connector.
You do all this work to your ski but take a harness in to get it extended?? I believe in you! Pick up some heat shrink terminals and some heat shrink tubing and you can have it done quick with minimal tools, or solder and heat shrink.
Otherwise you can get the start stop side sub assembly with switches for like 80 bucks or so from Jetmaniac in the SJ length.
  • Like
Reactions: Req
Roseand
The Weaponizer
Wisconsin
I am a lazy failure at life. I am capable however unwilling.
Thanks for the lengths!
If anything little electrical work like that can be therapeutic and satisfying!!
Are you maybe a little tired from sanding and cutting and grinding ever inch of a squarenose over the past few months??
Req
SW Tenn
That is definitely playing a part. Additionally its my weakest skill next to carb tuning so stand by for noob carb questions in the coming weeks!
