Found
For a bone stock 650 the stock stainless Balster 1, WaveRunner III GP, VXR Pro prop works good and is really cheap too although not as good as the ones you are looking for.
I have a nice, used, freshwater 9/15 hooker, that we re pitched to a 10/16 (If your ski is a 701-with pipe, head, ect the 9-15 is not quite enough)
$250 + ship
John
watcon@watcon.com
$250 + ship
John
watcon@watcon.com
Hello John, I have a carbon xft superjet and just purchased a solas 144 mag stator pump from a friend. I'm interested in this impeller if it works for my application? The engine is a 62T bored out to 760cc 185 psi, group k porting, scoop grate, dual 44's, B pipe, bla bla bla. Its just a rec ski and I'm not a big freestyle guy so I don't mind losing a little bottom for more mid and top and I run it in mostly choppy water. Would this impeller work well? I think I need a big hub for the mag pump? What else do I need with it? A spacer, bearing kit, etc...? Do you have those too that I could buy with it? Thanks for your help!
