Ever since reading the two stroke tuning handbook and learning about Walter Kaaden I’ve always been interested in expansion chambers. The concept being, you can get a lot of performance out of a single pipe, but maximum performance results from properly designed chambers dedicated to each cylinder. A few examples below.
Has any research been done to see if this is possible in the standup world? I’ve found somebody on YouTube jam a 951 into a seadoo x4 hull with full pipes, and the snowmobile world gets pretty creative with pipe design to make it fit.
First obvious theory as to why this has never been done, I’m guessing there’s just not enough room in a standup hull?
Second theory is that these racing applications have a limited CC figure, so they’re squeezing extra HP out of any area possible. While in the standup world, if you want more hp, just buy a bigger engine...
Third theory, no company wants to do the R&D to fit dual pipes, while there is no market for it since everybody has different engine/hull combinations. That being said, in the future will we see hulls specifically designed to allow room in the nose for dual lay down pipes?
What are your thoughts on why this has never been experimented with before? Does anybody have knowledge of this research being done by factory, tnt, lay down pipes etc? Any prototypes made?
Brett
Brett
