- Puerto Rico
Update?
Sorry, work has been crazy this week and haven't done much on the ski. As for the midshaft, I took my Cold Fusion alignment tool, bored the hole to same diameter as the recess in the hull, and used it as a spacer.
To this point, engine is in, shimmed and bolted. Waterbox and pole are also installed. I did have to grind the lip from the rubber strap holders so the sit flush against the hull, since the insert area is wider.
Tip 1: Put breather hoses through the hull/bracket BEFORE installing pole. Dont know if this is common knowledge, but it's my first time with a RRP pole...
Tip 2: chase the threads in all waterbox, tank and battery tray inserts before installing.
