- Uk
Not sure is this is a common problem...
When I bought my ski (Rickter XFS DASA 1200) it had the original OEM cables thet were years old and it didn't crank very well.
Cut cabes open and were a horrible rusty colour.
Replaced the cables with a Marine flex 16mm2 tinned cable, cranked perfectly.
Less than a year down the line and its starting to crank slow again when cold and can see a rust discolouration down the starter coming out the end of the cable.
The 16mm2 cable is rated at 110 amps, im sure its pulling well over that cranking the Dasa.
The 25mm2 is rated at 170 amps. Do I just need to uprate the cables?
Anyone else have this issue?
Cheers Rob
Cheers Rob
