I just Picked up a WDK ROK-R and it has no bulkhead to separate the bilge area from under the tray. The versi plugs (look like home depot versions) on it now were not put in right and let in a ton of water. The area under the tray looks like it was filled with either expanding foam or sprayable foam. probably the latter. So the question is should i attempt to make and install a bulkhead then a scupper or just replace the drains? It seems like it would be pretty hard to add anything without stripping the ski and then opening up the tray which is something i don't want to do right now. Also the ride plate covers the back area of the hull and it looks like the drains were just put through the plate. Im guessing i should just cut the plate in that area but there are mounting bolts there. And lastly are there any other options besides the ball drains? I know the flappers are another choice but usually just one big one and for a scupper not just an open drain. or should i just seal them up all together and rely on my bilge pumps?
Rambling
Anyway lets here your .02
			Rambling
		 should totally work right? Joke
