Flash-FX
No Square..No Round..FX-1
- South Jersey Shore
Like mentioned above, check for crankcase and head o-ring leaks. It's good to start with a properly "sealed" motor. Remove the head and check the O-Rings (they are probably chewed up). Make sure the domes don't sit flush with the head sealing surface. There should be a interference fit (the head is squeezing the domes on top of the cylinder liner) of approx .003"-.005"... What doe's the engine builder recommend? Also check the groove where the O-Ring seats. I've found that the viton O-Rings are a bit chubby and get squished out not allowing a metal to metal surface seal if not addressed. The groove most likely needs a touch of machining to get the O-Ring to set in the groove better.
As for the carbs, It's pretty much trial & error (jetting). But I have found that (because of the PFP headpipe), the jetting from the front carb will end up being different from the rear carb. The front cylinder will require a bigger size of jets than the rear. These motors generate high crankcase pressures that make it easy to run high pop-off #'s like 24-26 psi. BTW, check your reeds for good sealing as they can also give you a false rich condition when not tight against the stops.
How do I know this stuff?? I have a SS900 that was/is loaded with tuning "gremlins". With my carbs, (I have 3 different sets to experiment with) the low speed screw likes about 5/8 turn out from seated. If I try to open them out more, the motor will load up and it gets real muddy.
