yama_freak615
MIA
- Middle Tennessee
1.) You're not a casual rider, and you do that calculation often.
2.) Your casual Seadoo'er will screw it up before the oilpump, and proceed to blame it on the motor.
what he said :biggthumpup:
95 percent of the guys here are running 701 two cyl yami based platforms, carburetered 2-strokes. Understandably, it is of course different on a DI engine platform. Which engine are your referring to exactly?
your not serious are you?
The actual pump for the oil injection I believe is controlled by the rotation of the flywheel, at least on a kaw 650sx it looked like it was, like a screwdriver almost...which means that its basically impossible for it to fail, but like everyone has said its the other stuff you have to worry about.
No not reeeeeeeeaaaaaaaaallllllllyyyyyyyyy.:woot:
Do you have any idea how many of those old 650 pump tangs that I have seen twisted off? Yes they can fail and Kawi ate a bunch of engines when they did,they did change the design of the pump but I still have seen some of the newer pumps fail also.
No, that's true. In fact, that's one neat advantage of the oil injection. It is metered, meaning that the ratio at low RPMs will be quite low (1:100? IDK) and in upper RPMS it gets higher.
Oil injection is fine for sit down. Most newer sit downs have to have oil injection.
I would never use it on a stand up.
