- Mn
I know it has been done. I read that thread (first time setting up tl). Anyway maybe someone can help me and others by creating more then one. So I guess we can start with my situation. Here is my setup: set up for freestyle :
.2013 Trendsetterz built fiberglass Backie Chan, 148mm 12 vein h20 designs torrent ss setback pump set up for dual cooling, wdk lay down pipe similar to a powerfactor pipe, pfp water box,1107 ET ,46 SBNs, lightened msd flywheel . Msd total loss.
I have made contact with Art at ET and this was his suggestion:
Race gas setup
32 initial
Start to retard at 5500
Target 7000 at 20 deg
7850 rev limit.
Pump gas setup retard stator 2 deg same map otherwise.
This being my first time setting one of these msd total loss ignitions I need a little more detail.
Any help will be greatly appreciated.
This was my guess of what he means
So I dug into the directions a bit. so set the stator to fire at the 35 degrees mark on the flywheel and set the dip switches as in my picture below? So if I did my math right at 7000rpms I will be at 20 degrees.
Race gas setup
32 initial
7850 rev limit.
