08 superjet twin carb 38mm
I’ve been having issues with a low end bog hesitation since I bought it, I recently went through the carbs and cleaned everything out and put back together. I took it out today with a full tank and it was running good but when I would turn right it would always shut off. Guessing an electrical issue.
By the end of the session it started bogging at high speeds and low speeds even more then it died and I couldn’t get it to start back up. Spark plugs are fine and when I took it home if I spray fuel mixture in the butterflies it will start and shut off. Any help on figuring out why it’s not getting fuel all the sudden? I double checked all the fuel lines everything is in correct place
