- Clearwater, FL
Custom x-2 build...need some help on where to start with jetting... i understand this can be a tough one to answer but i just need a starting point. hoping to find someone who has built something similar.
750 big pin bottom end (stock)
sxr 800 cylinders (pretty much...#24 small pin casting with sxr sleeves. casting ported to match sleeve ports)
bored out to 83mm
kawasaki "b" head (29cc)
sxr factory wet pipe
dual 44 mikuni carbs
i plan on doing whatever decking/gasket mods to get to 180-200 compression...nothing is assembled yet.
93 octane (if that matters)
95 sxi ignition. (stock)
any suggestions on where to start with jetting? didn't have much luck surfing the interweb for people who run dual 44s on their SXR 800
bored out to 83mm
