- jacksonville florida
pull low speed jets and make sure they dont have something in them.
What is your jetting btw? Popoff PSI? Is popoff sync'd? Have the fuel pumps ever been rebuilt and if so, how recently?I bought new needle and seat, spring and jets. Should come in next week and we shall see what happens.
Did you also change the check valves on the metering blocks?
Yes, I replaced everything in the fuel pump including the check valves. My little fingers hurt from that haha.This is important, I have seen many people, myself included, become guilty of giving them a good visual look and determining that they are "good to go" and then skip on replacing them when rebuilding carbs.
I've also learned over some time that despite them LOOKING and SEEMING fine, their ability to seal against the fuel pump body weakens and will create fuel starvation issues like the ones you describe.
It might be worth cracking them open again and replacing them even if they they are relatively new? Pay extra close attention to the direction they are installed. Also make sure your plug wires are new/cut back. I've seen people swear they have carb issues and it ends up being a electrical thing
...but what about the metering block check valve?Yes, I replaced everything in the fuel pump including the check valves.
Currently changing all of the internal bits, just waiting for T handles to put back on and test.Have you tried different popoff springs.
Are your racing in novice limited? Looks like they ditched novice lites this yearYep, with WF only weeks away going to do head gasket and remove choke plates.
No limited, I'm running womens am lites. It will be a game of attrition since this ski is basically a stockerYep, with WF only weeks away going to do head gasket and remove choke plates.
