Quinc
Buy a Superjet
- California
Haven't used one, but looks like it would work. Adjustable from 1-30psi
http://www.ebay.com/itm/151957388522
	haha Yeah I saw that delivery date on Amazon and was like screw that. If that first one doesn't work well then I'll probably get a legit one from JetWorks, considering an even cheaper $4 one most likely won't work any better. My only concern with these alternatives are rust/corrosion on the ball and spring.Bought one! I will let you know in 2 months when I get it. haha
http://www.ebay.com/itm/Turbocharge...ash=item25c3a0e8a4:g:d~MAAOSwMgdX0Lh1&vxp=mtr
	I did noticed it. The bolt that tightens the top piece down covers it. I just swapped out the spring to a much shorter yet stiffer kind. Either way, it didn't work out as well as I'd expected. They're not really designed for water as the passage way is a bit limited. Oh well, for $4 it was worth a shot and good to have around for another application. I got the pro FCV on the way anyways.what you clearly didn't notice is the bleed hole in the threads. it will have to be JB/welded/plugged or its going to squirt water as soon as the valve opens
Haven't got mine yet. Have you tried hooking it up to a hose to see how much pressure it takes to open?
