Looking for some help. I'm at a point where I'm ready to give it up for the rest of the season. Done nothing but spend thousands of dollars on this thing and countless hours wrenching on it. Iv rebuilt the motor. Brand new gaskets, compression test, leak down test, you name it. It just won't run right. If someone is willing to give there insight I would appreciate it, or if someone is willing to get it running with me there time is worth something.
Quick explanation what's going on:
-It has "ran away" on me twice now out of the water
-Barley idles and runs like crap on the stand, even sounds like garbage
-when in the water in barley gets on plane. You maintain the same throttle and all of a sudden lights up and out of the water it goes. Let off throttle and back to a bog.
All I changed was flame arrestors and went from a 115g pop off springs to a 95g as per Chris from jetmaniac recommendations for the new filters.
Ignition is oem with msd boots. MSD enhancer on its way.
Attached are some pictures of my carb and stator. Is the timing right? Looks like it's stock timing and isn't advanced or retarded any.
Reeds are in good shape. One was starting to curl a bit so i removed it and flipped it to make it "seal" again.
I did another leak down test with flywheel off and you can see the small leak on the front crank seal. Will that SMALL of a leak cause this issue. Funny that the mag side piston did score a bit before rebuild. But having a very hard time thinking that is my issue now.
The motor was a 718 jetmaniac build. It's now bored over fresh with 83mm(735cc) piston.
Help...
Sent from my SM-G955W using Tapatalk
Help...
