Fuel octane selection
DylanS
Gorilla Smasher
Lebanon Pa
So I know the basics on what octane means, and that the higher the compression ratio is the higher the octane should be to prevent premature combustion
But I'm still experimenting with my fuel mixtures, and would like to hear what you guys have to say on the topic too
I have about 200 pounds of compression in my motor
And it seems to run best at a mix of 4 gallons of 93 non ethanol and one gallon of 110 AV gas
Maybe could be better, what do y'all run?
DylanS
Gorilla Smasher
Lebanon Pa
Only have 91 around here no 93.... 200 psi 50/50 91/110 no long wide open.... 225 psi straight 110 or ms109...
I tried half half mix and it seemed to run poorly which is odd
That should be the right mix
Thanks for the input though, I see you a lot around here lol
Stockton
Welcome, ya I should have mentioned it's not AV gas but leaded 110 race gas...
And the ms109 is unleaded gas
