Pump and midshaft housing uses different shims then the motor. Jetmaniac had everything you need.
Yami-Rider TigerCraft FV-PRO Location Texoma Jul 19, 2017 #21 Pump and midshaft housing uses different shims then the motor. Jetmaniac had everything you need.
hbuk24 Location Spain Jul 20, 2017 #22 Yami-Rider said: Pump and midshaft housing uses different shims then the motor. Jetmaniac had everything you need. Click to expand... Ok, im in Europe so will have to try and source them over here
