Vumad
Super Hero, with a cape!
- St. Pete, FL
Great blog post by fiberglass coatings inc. they are local to me an have taught me most of what I know. This is great info if you plan to make a mold and part, use my on-the-part method of repair or even if you are making a repair without a mold (can just skip a few steps).
This is one of their best blog posts. You can follow them on Facebook as Fiberglass Coatings Inc and can also be used as a supplier.
https://blog-fgci.com/2016/11/03/how-to-guide-hand-lay-up-on-fiberglass-molds/
How-to Guide – Hand Lay-up on Fiberglass Molds
November 3, 2016FGCI
1. PREPARING THE MOLD
Remove dust and dirt from mold.
a. If mold is of plaster, wood, or new fiberglass, apply soft wax (Wax #2) and buff with soft towel. Then spray or brush with PVA parting compound and allow to dry.
b. If mold material is glass, metal, ceramic, or well-cured fiberglass, apply three coats of hard wax, carnauba type, buffing between each coat.
2. APPLYING THE GELCOAT
a. If gelcoat is to be brushed on, allow the first coat to cure and then apply second coat to make sure there are no light spots.
b. If gelcoat is to be sprayed on with a gelcoat gun, spray up to a thickness of .015” to .020”. When gelcoat has cured long enough that your fingernail cannot easily scrape it free (test at edge of mold where damage will not show on part) then proceed with next step.
3. LAY-UP SKIN COAT
Cut ¾ or 1 oz. mat to cover your part. Brush catalyzed resin over the cured gelcoat and then apply the mat. Work with the roller, adding more resin where necessary until all white areas in the mat fibers have disappeared and all air bubbles have escaped. A mohair roller is ideal for rolling in the resin, and a ribbed plastic or aluminum roller assists greatly in popping any remaining bubbles. Avoid leaving excess resin standing in puddles. Resin-rich areas weaken the part. Where rollers will not reach, brushes must be used. When this step is complete, clean all your tools in acetone. Allow skin coat to cure before next step.
For a 12 ft. boat, two layers of 1½ oz. or 2 oz. mat and one layer of roving may be adequate, depending upon design. For a 14 ft. boat, an additional layer of mat and roving will add additional strength. Apply each layer as in step 3, but it will not be necessary to wait for curing between these layers. Be sure to shake all acetone out of brushes and rollers before applying resin. Acetone drips can result in uncured spots in the lay-up.
- LAYING FIBERGLASS REINFORCEMENT
On a small lay-up, the fiberglass laminate which hangs over the edge of the mold can be trimmed off easily with a razor knife if you catch the “trim stage,” of the period after the lay-up has gelled but before it has hardened. On a larger lay-up, it can be trimmed with a saw or diamond blade.
- TRIM
The cure may take from two hours to overnight, depending upon turnover desired, temperature, catalyzation, and nature of the part. If laid up in a female mold, longer cure will affect shrinkage and easier parting. In the case of the male mold, the part comes off more easily before it shrinks appreciably. If the part is subject to warping, a longer cure may be necessary. In any case, when the part is removed, it should be supported in its desired shape until fully cured.
- CURE
First, examine the trim edge all the way around the mold and make sure there is no resin bridging the line between the mold and the part. Sand this edge where necessary. Then wooden or plastic wedges can be pushed into the edges to start the separation. Continue separation by pulling and flexing. In some cases, it is necessary to drill a small hole in the mold and apply air or water pressure.
- REMOVE PART FROM MOLD
Trim edges and back of part may need to be sanded and coated with surfacing resin or interior gelcoat.
- FINISH
“Alligatoring,” or wrinkling of the gelcoat may be due to the following reasons:
- GELCOAT PROBLEMS
- Gelcoat is too thin in spots; consequently it does not completely cure.
- Insufficient hardener added, or hardener not mixed well enough. In general, it is best to use about twice as much hardener in gelcoat as in lay-up resin at the same room temperature, since the gelcoat goes on thinner than a mat lay-up.
- Gelcoat has not cured long enough before mat lay-up.
- Acetone from tools drips onto gelcoat or into skin lay-up.
