JetManiac's Exhaust and Cooling parts shop
Exhaust gaskets
U.S. made high quality SS reinforced gaskets
Factory Pipe headpipe gasket $9.95/ea or 3 for 9.49/ea
(Stock FP headpipe gasket 47mm)
Factory Pipe Big Bore headpipe gasket $10.95/ea or 3 for 9.95/ea
JetManiac has big bore headpipe gaskets for all your bored pipes!
Big Bore B-pipe headpipe gasket is about 51mm
Factory Pipe/Kawi/Coffman sizzler 45mm headpipe gasket 9.95/ea
62t 701/760 exhaust manifold gasket $14.95 sale 9.95 (top in pic)
62t 701/760 with 8mm helicoiled 61x size holes 12.89
61x exhaust manifold gasket $14.95 sale 9.95 (bottom in pic)
650/6m6 exhaust manifold gasket $12.95 sale 9.89
JetManiac Factory Pipe B-pipe gasket set $19.90
FP headpipe gasket and Yamaha exhaust manifold gasket (61x or 62t)
Riva red pipe headpipe gasket $14.99 sale 12.89
Coffman 4 bolt headpipe gasket 9.95
Pro-Tec 4 bolt headpipe gasket 9.95
Coffman sizzler 3 bolt headpipe gasket 9.95
Kawi 750/800 Bpipe gasket kit 18.90
Kawi 650/750/800/900/1100 exhaust gaskets also in stock.
Exhaust Hardware/Bolts
JetManiac Factory Pipe Headpipe SS Bling Bolts
Do your factory pipe headpipe bolts look like the ones on the left?
Replace your rusty headpipe bolts with JetManiac's Stainless headpipe bolt kit.
If you have ever tried to find this bolt size locally, you know they aren't available in the US. These were sourced by JetManiac in Asia to get this rare size.
Bpipe headpipe allen stainless bolt kit $19.95 (on right side in pic above)
* 3 Stainless Allen head headpipe bolts, SS flat and lock washers)
Bpipe 61x exhaust manifold stainless bolt kit 19.90 (on left side in pic above)
* 6x stainless allen shorter bolts with washers
* 2x JM special shorter small head ss bolts for top middle of mani
Bpipe special stainless 10mm headed bolts 5.95/ea sale 4.95
* for the hard to reach and tighten top center 2 Bpipe manifold bolts
WAX headpipe bolt kit (much longer than Bpipe bolts) $24.95
KAWI longer Bpipe stainless headpipe bolt kit $19.95
PFP, RRP, TNT pipe SS allen exhaust manifold bolt kit 19.90
* 4x longer allen stainless bolts/washers for manifold ends
* 2x shorter allen stainless bolts/washers for manifold top center
* 2x special shorter small head stainless bolts for bottom middle of mani, hard to tighten location
61x exhaust manifold bolt kit OEM clean, used 9.90
62t exhaust manifold bolt kit OEM clean, used 13.90
M8 long helicoils 2.25
* for 62t 701 or 760 cylinder to mani M10 threads to convert to 61x M8 bolts
Couplers and Exhaust hoses
Bpipe coupler
Bpipe Silicone Coupler -Factory Pipe Bpipe headpipe to chamber $26. sale 19.95
(Blue, Black or Red)
New JM Bpipe HD coupler clamp 11.95
(These clamps have one of the highest clamping force ratings of all worm gear style clamps due to the fine thread pitch and riveted housing. The non-perforated band with rolled edges eliminates hose damage while increasing clamping force.)
JM Coupler install Tech Tip:
http://www.x-h2o.com/index.php?threads/tech-tip-bpipe-exhaust-coupler-installation.156252/
Dry pipe Silicone Coupler -Factory Pipe Dry Pipe headpipe to chamber 24.90
(all- Types 4, 8, or 9)
Coffman large chamber coupler 27.90
HD Yami coupler clamp for Coffman-used OEM 6.90/ea
Coffman smaller headpipe to chamber coupler 16.90
ProTec pipe HD coupler 25.95
Power Factor Pipe, TNT Heavy Duty mani to chamber coupler 29.80
(Thicker and beefier than std PFP coupler)
PFP genuine HD mani to chamber stainless clamp 11.95
PFP chamber to waterbox silicone coupler hose 15.95
Chamber to Waterbox hoses
Silicone coupler for Factory Pipe 45deg -SJ chamber to RN or JM waterbox 39.90 sale 29.95
(Black, Red or Blue)
Silicone coupler for Factory Pipe 45deg -SJ chamber to XMetal or H2O designs waterbox
(these have smaller inlet than OEM RN waterbox) 39.90
Silicone coupler for Factory Pipe 45deg -SJ chamber to SN waterbox 39.90
OEM used hose elbow 45deg -bpipe chamber to waterbox 19.
Blaster Factory Pipe mod chamber to waterbox 90deg coupler 39.90
Blaster Bpipe limited chamber to U return pipe silicone coupler 13.
PFP chamber to waterbox silicone coupler hose 16.
Waterbox to exhaust outlet -Long hose
Silicone Long exhaust hose -waterbox to bulkhead outlet 109.95
(Black, red, or blue)
OEM used Long exhaust hose -waterbox to bulkhead outlet 104.80
PFP/ Laydown pipe waterbox to bulkhead outlet HUMP silicone long hose 109.95
Waterboxes
SuperJet and Standup
JetManiac lightweight SuperJet and standup ski waterbox $369. sale 339.89
Details here:
http://www.x-h2o.com/index.php?threads/jetmaniac-waterbox.181445/
RRP aluminum SJ waterbox 225.90
JM modded 30.
WaveBlaster
JetManiac B1 waterbox $419.90 sale 386.90
Details here:
http://www.x-h2o.com/index.php?threads/jetmaniac-waveblaster-waterbox.186284/
Laydown Pipes
RRP chamber to JM waterbox silicone reducer adapter 14.95
PFP laydown waterbox 269.90
RRP aluminum laydown pipe waterbox 225.90
RRP waterbox EVA pad for waterbox shape to contour bottom of waterbox 29.95
Waterline and fittings
3/8" T waterline nylon fitting 3.50
(needed for FCV install)
3/8" Y waterline nylon fitting 3.50
3/8" x 1/4" x 3/8" T waterline nylon fitting 4.95
3/8" to 3/8" waterline elbow 90deg nylon fitting 2.50
1/2” to 3/8” waterline reducer fitting 3.49
1/2" T waterline nylon fitting 3.49
1/2" x 3/8" x 1/2" T waterline nylon fitting 4.95
Translucent blue 3/8" water line 1.79/ft
Translucent green/orange/red/clear black 3/8" water line 2.99/ft
Black or blue silicone 3/8" water line 2.99/ft.
Hose clamps for 3/8" waterline 2.39/ea
10pack 2.09/ea
(Marine grade all stainless steel clamps, US made)
Black silicone 1/2" water line 3.49/ft.
Spray bar for water injection 39.95 sale 37.89
Water filter for PFP pipe 19.90
Water strainer -Inline 3/8" waterline filter 28.75
Brass fittings for use on manifolds, pumps, heads
90 degree 3/8" hose fitting 5.49
90 degree 1/2" hose fitting 5.95
Straight 3/8" brass hose fitting 3.95
Straight 1/2" brass hose fitting 4.95
Rare 45deg brass hose fittings
3/8" 9.80
1/2" 10.90
Brass hose blockoff plug 2.95
Universal inline flush kit 20.90
Flush kit for Yamaha OEM SJ, Blaster pipe mount 24.80
Flow Control Valves
Flow Control Valves
Flow Control Valve dries out the waterbox at low rpm for more low end power for freestyle or racing.
JetWorks FCV red Std adjustable red flow control valve 49.95
(uses different thickness included washers to adjust)
JetWorks FCV blue Pro adjustable flow control valve 54.95
(screw valve body in/out to adjust)
Water Restrictors
JetWorks screw to adjust flow water restrictor 33.95
JetWorks new style water restrictor 33.99
(with 3 delrin inserts)
OEM throughhull waterline fitting(clean, used) 3/8" 8.90
OEM throughhull waterline fitting(clean, used) 1/2" 11.90
Exhaust mounts -Lord mounts, ProTec mounts
Short (1" rubber section)-male to female 29.90
(Blaster limited and mod bpipe)
Short (1" rubber section)-double male 29.90
(Blaster mod bpipe, Kawi 750SX)
Tall (1.5" rubber section)-male to female 52. sale 39.80
(Blaster limited bpipe, Superjet FP Dry pipes)
Flywheel cover Lord mount stainless bracket 40.95
Coffman exhaust mount rubber insert 9.95
Coffman pipe mount rubberized washer 9.95
Bpipe headpipe adjusters
Bpipe Headpipe std size replacement adjuster screw kit 27.50
Bpipe Headpipe std size T-handle replacement adjuster screw kit 32.50
Oversize Bpipe headpipe replacement adjust screw kit 39.50
(includes drill bit, tap, oversize hardware, and instructions)
Oversize Bpipe headpipe replacement adjust screw 9.89/ea
Exhaust gaskets
Bpipe coupler
Waterboxes
Details here:
JM modded 30.
WaveBlaster
Details here:
Laydown Pipes
10pack 2.09/ea
3/8" 9.80
1/2" 10.90
Flow Control Valves
Flow Control Valves
Water Restrictors
