Iam new to hitch hauling and a buddy told me bed launching and hitch haulers are not allowed in disco bay. Co-worker told
Me (the reason why is trucks are backed in so far that the rear tires Loose traction to the ramp at times and the whole rig goes in the water.). E-brake's and park pawls hold rear tires from rotating but if the tires Loose traction to the ramp then in the lake you go.
I don't want to be that guy so I looked into launch control devises used n drag racing to do burn outs, soliniod blocks front brake pressure from returning to master cylinder, locking only front brakes until released. After consideration on my street truck this method posed to many risks, all I need is the circuit to malfunction and get blocked on a long step grade when Iam loaded and it's lights out.
Also considered the sticks that hook the steering wheel but if rear tires leave the ramp and the winds blowing the truck could move sideways releasing the brake stick so that's out...
So I came up with this stick, it applies full hydrolic brake pressure manually. Will hold truck in gear with no e-brake applied. Once I've backed in with my foot still on the brake I install the brake stick. I slotted the knee bolster panel below the steering column to hook it too. Little bit of turf to help find the slot lol. Works great. Later model
Vehicles can have knee air bags in that panel so be careful.
That deep second deep spot didn't applie enough pressure to hold truck in gear so made a shollower one so I have options
Edit: removed a cause
LHS
LHS
