DAG
- Charlotte, NC
Dang 15 balls per pound. Way more than I would have thunk. Leave it to myth busters
Here's the summary of that link;
Flotation needed to support the swamped boat.
Formula: Fb = A ÷ B = X cubic feet of foam
A = Submerged weight of hull, (who would really know this value?)
B = will be calculated as follows (assuming use of Polyurethane foam of 2.0 lb. density) B = 62.4 – 2.0 = 60.4; then allow for 5% moisture absorption (2.0 x 0.05 = 0.1) B = 60.3 lb.
So, by that equation, a 325 lb ski with 2 lb foam will require 5.4 cubic feet of foam but we know that is not exactly true as that's a poop ton of foam!
I am guessing a stock ski only has about 3 cubic feet of foam at the most to achieve neutral buoyancy so I'm going to estimate the construction of the ski itself accounts for around 125-150 lbs of net buoyancy.
So, weigh your ski, subtract 125 lbs, take that result and divide it by 60.3 and that is roughly how much 2lb foam you need to achieve neutral buoyancy.
Feel free to add extra if room allows.
Simple right?![]()
1 night (drunk) I came up with a design. I will share it just because. Have a tube just like a scupper ( or to replace your scupper ) but it screws in the tray. In the tube would be the air cartridge and inflatable float It would have a handle to pull to deploy and would be in the tray out of the way.
First you have to determine how much is already in it. Then it's just a matter of adding a safety factor with additional foam anywhere you can fit it.
Surely it is posted already how much or what type of foam the Rickters come with?.?.?
You might be new to all this but this topic has been asked and answered countless times already, you just need to search out and copy what others did. Plenty of Rickters out there that have been sunk and recovered already.
I have been working on a design that would retrofit under a OEM bond line, the whole time i was trying to be the least invasive, but thats awesome! Back to the drawing board!1 night (drunk) I came up with a design. I will share it just because. Have a tube just like a scupper ( or to replace your scupper ) but it screws in the tray. In the tube would be the air cartridge and inflatable float It would have a handle to pull to deploy and would be in the tray out of the way.
What if you could put an inflatable PFD inside and pull a cord before it sinks? It wouldn't be foolproof because it requires manual activation, but I bet it would work in 90+% of the situations. Not sure if it would keep it afloat.
Not sure how much it would cost to custom make something along the same lines that would fit in the full better. It would be pretty cool though because it weighs practically nothing and would take up minimal room in the hull when not inflated.
Thats the concept, but you need more air. as we are mainly water, we are naturally boyant (Most of us at least..), but the ski is the opposite. a 50lbs rock would sink a life jacket, but a 250lbs person wont. Based on my math you would need about 5 cubic feet of air, which is around 5oz of C02. Smallest that can be made is a bit larger than the size of a fire extinguisher, and around 7-10lbs minimum. Ive estimated the size would be around 2.5-3" tube ID, 12-15" long.What if you could put an inflatable PFD inside and pull a cord before it sinks? It wouldn't be foolproof because it requires manual activation, but I bet it would work in 90+% of the situations. Not sure if it would keep it afloat.
