Tricks On A 650sx??? Is It Possible??
kawasaki168
kawasaki168
Ok Got A Few Q's Bouit Tricks. My 650 Is Pretty Much A 750! It Kills In Acc. It Was Skat Trak Pump And Impeller. Piped And Everything Else U Can Do To It......now Is It Possible To Do Barrel Roles And Nose Stabs And Other "ariel" Tricks On This Ski?? I Am So Close To The Barrel Role But Jus Seem To Lag Power!! Is It Just Me Or Can This Ski Just Not Performe The Way I Want It To?
Can Anyone Please Send Me Some Tips On Going Big On The Old Skool Ski's!!???!!!??
Waste Land
Non Multa Sed Multum
Florence, AL
Can be done. Not as easily as a SJ, but yes can be done. Even more so in the ocean.
Just takes practice
RiverRat
Louisville, Ky
Yes it can be done but the hull will take a beating. I started out on a 650sx and by the end of the summer the handlepole was cracked in 5 different places, hull was cracking on the side, hood was cracked. Pole finally gave way, switched to a AC pole then parted the boat out for a SJ. The 650 was just not built to take allot of abuse IMO. I even reinforced mine.
KaosFreestyle
White on White
Mequon, WI
I just put footholds in mine. Id be impressed if I was actually able to nosestab the ski now. I am for sure not getting it to do a barrel role or anything that might take it inverted.
yamanube
This Is The Way
Staff member
Mandalor
A guy I ride with used to ride a stock 650sx, maybe an impeller and he could do them....I would maybe throw a carb at it(and impeller)! Probably rather do a carb versus paint.
You can do a hell of a lot of tricks with footholds,pipe,impeller,intake with just that! meanin all up2 brolls (Roy could roll a 650)
From 2brolls,flarrelrolls ......+ you need the $$$$ imo.
Exile.
