- Chicago
Figured id ask before i wiff it. Planning to build beach cart and a shop cart this winter.
Thanks for your time i appreciate it
If u plan on coming up by Illinois this winter i weld for a living lolPlanning to build mine like the Big foot.
Should be able to cut everything like I want then take it to a welder.
I ordered from onlinemetals.com. Probably way to much material but it was only 180.00 with coupon code for free shipping.
Carbon, stainless, or alum?That is an excellent question! I just ordered 2 inch square tubing to have one built.
Aluminium.Carbon, stainless, or alum?
Good deal, im prob gona make mine out of stainless, Or carbon. Depends if i have acess to an aluminum machine at the time. if i make it from carbon with stainless wire, jumbo cup, and clear coat it, stainless filler wire on carbon steel makes a rainbow color and the welds look sweet. Plan on buying an enclosed trailer in the spring i could just wheel it in who cares if its heavy. If your going to have aluminum welded make sure you take it to a good welder that will tig weld it and not that wire spool bs. Aluminum is tricky and without a trained hand you may have welds breaking on you and then you have your expensive ski laying on concrete or your 200 mile weekend ruined not able to put your ski in the water cause of some jerk off who claimes he can weld aluminum. Also, for future reference do some research and look up uour local metal supply houses, should be much cheaper. especially down by you in GA. Im from Chicago and all metal is $$$$&:&Aluminium.
I am a little concerned that it will. I almost cut the tubes a few inches but started worrying that the tires may touch the hull like my old one did. Took the gel coat right off!Looks good, looks like your ski is going to be higher up than most.
