So I have a 3D printer and I just thought about making plugs/molds with it for fiberglass work. Anyone done this? Got any ideas of what I could make? Im thinking maybe a mold for a lowered RN nose piece...
Man! Must have been a very large printer lol.Guy on here by the name Dalton 3d printed an entire top deck, glued it together and made a plug. Not a lot of details were given, but I'd imagine it still took a bit of effort to sand and prime before making the mold. The 3d prints I've seen are pretty porous and would definitely not release a part or be released from a mold very well.
Oh ok cool. Im gonna start designing a lowered nose piece. Ill update the thread with pics if/when I get something made.Ask Nate_D, I'm pretty sure that's how he makes a lot of his molds and his stuff turns out incredible.
Anyone else got any ideas on some parts to make? Maybe a front foothold...
Thanks!
I 3d print a lot of my plugs now. All of the molds for the twin tube adjustable poles I make were made from a 3d printed plug. I've also tried to 3d print molds. These have not been successful. Even if you can get a surface smooth enough, the plastic has too low of a tg and deforms when the part cures.
As for prepping the plug, it really doesn't require much work. Especially if the plug can be printed in one piece. It helps when designing the plug to design a small flange on it. This helps when you go to glue it down to your flange board, as you don't have to worry about making a fine seam between the two. Without the small flange, you have to be very careful to get a small and smooth transition from your plug to your board.
As for prep, I take a 3/4" plywood board and hit it with a poly high build primer while the plug is printing. Once cured and the plug is printed, I'll smooth the board with 80 grit DA and then lay down body filler to the base of the plug, gluing it to the board. After that, I'll fill the gap between the board and the flange on the plug, hit the plug with 120 grit lightly, then spray the whole thing with poly high build. Sand with 180 smooth and then duratec surfacing primer. From there it's wet sanding and compound/polish.
Here's some pics if you are interested.
Here's the finished product from the molds
There's definitely a limit to the cost effectiveness of this approach. The larger the part and the more sections you have to cut your part into, the more time involved in getting the plug ready to be molded. At a certain point, you are better off having a shop cut your plug from high density foam or mdf. Unless you have an industrial size printer.
Another downfall is that the tolerances with this method are about +/- 1mm. While that is fine for a lot of parts, there are times when that simply won't do (the tubes in the pole for example).
For all the print material you're going to print. You're better off paying a large scale CNC house to cut a hull size foam block into a plug, and finish that.
