N3vrSat1sfied
Military Member
- Fort Worth, TX
@cookn makes inserts for wear rings to run stock 144 long pump bolts.
The 144 bolts are a much smaller bolt though and would be loose going through the stator and nozzle. I wouldn't use them on a 155. You could also buy a skat wear ring and it will come threaded for 155 pump bolts.
