I have an ADA head that was torqued to spec (slightly beyond). I have a new JM735 that's in the process of being broken in, and after my first tank of 91 w/32:1 gas, I realized that my compression was low (150) so I ordered a new o-rings and reinstalled the head. I did notice a very small amount of pitting on one of the domes. I know pitting is usually debris in the cylinders, but there is 0 pitting on the piston, and no scuffs on the cylinders. Any thoughts?
-62t bottom end (Raider)
-61x 735 (ported)
-ADA Head with 35cc domes.
-Carbs at default settings (per recommendation)
-No more than 3/4 throttle pulled for the first tank (second tank is filled, but not ran)
-61x 735 (ported)
