- Point Pleasant, NJ
Hey guys
All stock superjet 701 dual 38s with a raider motor in it
I started having a low end bog so I rebuilt the carbs and set everything to factory spec
Pop off 55psi
Low adjusters 1 turn out
High adjuster front 1 1/4
High adjusters rear 1 1/2
So I start the ski and it idles great but when I go slow on my knees it wants to run out of fuel it seems like, if I start blipping the throttle it will get worse and worse until it stalls
It fires right back up though
Weird thing is if I get past the low jet and into the high it runs great
I've adjusted low speed screws from half turn out all the way to 2 1/2 turns out with no change
I already pulled carbs apart twice, there is nothing in the low jet
I can't say it would be fuel selector because high speed is great
One way valve is new as well
Pop off 55psi
