How many layers of what weight glass did you use?
depends on the location and if I built up on factory smc. Generally, in spots that I built up my own shape (like the pump and the nose) I used 3 layers of 1708 biax and laid it in 45 and 90deg to each layer... and one layer of 5oz weave for a smoother finish. I think I did 4 on the bottom up by the nose and under the tank/waterbox; 1 layer to set the shape and built up 3 more layers for thickness, same with the rear where I shortened it. The sides where I built up on factory smc, I did 1 strip 5" wide all along the bond lines, then a full sheet of 1708, then carbon to purdy it up.
other updates: milling down the exhaust chamber gave me the needed clearance between the hull and chamber. Cut another 1.5" out of the waterbox to narrow it down worked as well; no rubbing issues now. Then ran a cooling line to it to quite it down a bit. Also put my mag pump in it and added trim, which works awesome on this ski. I know for a fact anyone with more skill than me could flip it. I was having to much fun on my Air Blair hull this summer, so I didn't ride it as much as I should have...rode a lot of surf this year. The wetjet motor lacks on the bottom end more than I had hoped, but I can work with it...I like the motor because it came from Kevin Bruin's; so it'll stay. Some pump pieces came from Bruin's and I put Bruin's custom turnplate and bars on it that he was making back in the day. Kind of a tribute ski to him, I think he would approve
