So, I recently went to put a FCV (brand new Jetworks red kind: 3/8" that you tune with washers) on my 6m6 SJ with a Coffman Sizzler wet pipe. I installed the FCV according to the pic below, below, and sat the ski into the water with the hood off and braced the ski so that it couldn't go anywhere. I disconnected the water line going into the stinger, and hung the FCV over the side. After I started the ski, I let the cooling system fill up with water and revved all the way up to the rev limiter, but the FCV did not open.
Before I start to cut the spring, I want to see I made a mistake when attempting to tune. When revving the motor, I didn't cap off the cooling line that went into the stinger. Could this exhaust leak have been enough to prevent the water lines from reaching full pressure?
