long beach local
long beach local
- Az
Here are some pics of my new ski sent to me by prowatercraft as it was being built, they are out of order. I just picked it up last weekend and have started assembling it and want to fit the aluminum tank in the front that will give me over 10 gallons of range for long rides without returning for fuel. The motor will be a ET 967 ss twin not a triple with a race spec tnt v3 pipe and waterbox 2.5 inch exhaust routed to left side . I am using a rhaas kawi to yamaha kit as i have alot of yamaha parts , motors etc to swap out if i desire . The pump is an older kawi 140mm skat setback 16/23 skat prop, ATP flame ignition , like new 44mm carbs the carbs and pump may be alittle small but i have spent enough money. The ski is long ,large , and lean the chines dont fit a tote like an sxr as the ski is wider and longer . This is hull #7 and i feel fortunate to own it. Fit an finish is oem quality its friggen gorgeous if you ask me
