Bigfoot Beach Cart messed up?
I have been waiting for quite a while for this to come and the winch won't fit on and the bunks aren't really working for my superjet, take a look at the attached pics.
I have contacted where I bought it from about the problem and am waiting to hear back but have you guys ever seen this before?
Delaware
Most people I've seen running that cart just relocate the bunk uprights in a little. You can do that by getting new pieces of the larger square alum welded on or just bolt to the existing uprights with ubolts to the inside of the originals. For the winch just redrill the cart or winch to open up so it will fit.
I realize you don't want to mod a brand new cart, or feel you shouldn't. But really it's not the dealers fault you bought a cart that doesn't work with your ski unless they specifically said it was made for it vs "would" work.
Edit: this is what I've seen for that cart to work. image.jpeg
Hmm, when I called they said it would work for stand ups. I'm not nearly as mad about the bunks as the wench as they both came together and don't even fit together. I would probably have to drill 2 new holes if anything but I would rather just return the whole thing at this point.
Yep, two different spacing options and you got the sit down version. As for the winch, they may have drilled the holes incorrectly or changed winch model and not picked up on the mounting hole spacing. It sucks when brand new stuff doesn't come together.
That is what I thought, thanks. I called and they are swapping out the back end for me :D
