OCD Solutions
- Rentz, GA
They do sell a drop in OEM harness for under $100 that replaces everything but the plastic shell. If you had multiple issues with your harness/connectors/buttons, I would recommend that route but if it's in good overall shape and just needs the pins cleaned and re-greased, I would give that a try before I spent the money.
Here's a good thread from the Tech section in how to clean up your switch.
http://www.x-h2o.com/index.php?threads/how-to-fix-your-sj-start-stop-switch.135834/
If you wish to replace it, here's the info on the harness;
Yamaha Part number EW2-68311-01
http://www.x-h2o.com/showthread.php...ken-shorted-or-damaged-start-start-assemblies
Jetmaniac has the best pricing on the start/stop assemblies if you go that route.
