air blair
you are the reason
- thumb, mich again
Because it's hard to get my garage 80degrees?
Air blair cell
Ping pong balls are expensive. I've seen 2L bottles and water bottles stuffed in there. Now that's cheap.
but I don't think you will ever beat the price of a 2L bottle.
Where's the structural integrity with ping ping balls? Seems kinda sketchy.
Look at my build thread and you will see how it's done. Going on 3 years now with no issues.
Oem superjet yes is closed cell. If I owned a superjet the first thing o would do is drill a hole on both sides to let the water out. It's in there believe me. And it's trying like hell to break through the closed cells
Air blair cell
"Build strong enough to not need it for structure and run polystyrene and tray drains" is my political stance on this subject. I hate defoaming.
That's a 20 year old hull. Hard to tell if it will dry 100 %. Probably kinda like. Sponge now. Might dry up but absorb quick. Let it drain everytimeBut will it ever actually drain out of the foam once its in there? I have a SN hull that felt like it had water in it so I drilled it. Some came out right away and it continued to drain very slowly for a couple weeks, then it basically stopped. Even after letting it sit nose up all winter that thing it probably 40lbs heavier than it should be.
