Most of the info I have gathered from the forums, people are using 1208 & 1708 biax for building. I'm wondering if anyone has any better suggestions on what to use. As for finishing cloths/ fabrics I'm all ears to what you guys suggest.
I want this jet ski to last, plan on beating it. so it needs to be strong but weight is a concern of mine as it is a freestyle machine. looking for a fabric that is easy to wet out and conformable too. my layup will not be vacuumed bagged (first build) but I will be using bristle rollers and west systems epoxy resins (slow cure). planning to do my layup in two different steps being the outside first then reinforcing form the inside. I will need up to a 1/4 inch thickness in half the spots and the other half an 1/8th inch roughly. Any help on choosing the right fabrics/ cloth is greatly appreciated!
I was stoked on s-2 glass being that its both stronger and lighter; But when I went to pull the trigger I was informed that the weave (8 harness satin) is hard to get air out of. that it should really only be used when bagging, is this true?
any help is greatly appreciated I have everything ready for layup but no fabric. this has been hanging me up for awhile!
