waterfreak
I had a vision!
- s florida
after a full year of r&d and incorporating everything We know in our 12 years of hull building , we are very proud to introduce the new WCF Vision X AM hull. It is just not a re vision of the old vision hull (no pun intended ) but completely re designed from top to bottom . We just completed our water testing today and are completely over whelmed by the handling, stability and comfort ability of the ride.with this hull, You do not have to fight to keep the nose down and can adjust your ride by cutting the ride /hull plate Some of the features are as followed:
1) shorter and wider hull to increase stability and nimbleness
2) adjustable hull/ ride plate
3) re designed pump tunner to adapt 144 and 155mm pumps
4) low profile hood
5) added rocker and incorporated spray deflector
6) super wide tray and re designed rear entry footholds
7) easy engine bay access
8) redesigned side rails (45 deg)
9) aesthetically pleasing look and smooth design
10) all vacuum infused process
Price starts at $4995 and includes ride shoe , thrust ball scupper, hull drains and your choice of colored gelcoat and turf .
