My name is josh. I am the owner and builder of the Phantom hull. The hull is 73" long, has a widened keel, gradual front and rear rocker, strakes have been sharpened to create more lift, accompanied by drastically shallow chines, the ski rides more on top of the water allowing for even more stability at wot. Although this is primarily a flat water ski, it has capability of chasing down boats without being prone to porpoise like most short am hulls. With the all new pump tunnel design it completely eliminates all cavitation issues with today's large cc motor set ups. Accepts 155/160 pump shoes without any hull grinding but still accepts a 144. With all these changes coupled with the outside portion of the strakes being at an all new proprietary angle/degree I have created a ski that is both stable and releases the water. Enabling the rider to do combos and 360s. 100% straight exhaust tube without any bends makes for the best flow with any motor combination. Conventional style composite ride plate, all new motormount and insert design help save weight and just look way cooler!! Lol Xmetal hood latches and scuppers r used. Just the best imo!! Although options are available for versa plug users. I only use oem hood seals.
Tray has been lengthened 4" in the front, footholds are now larger, to accept more pad. Footholds moved forward not only to give the rider a more natural position but also by centering the riders weight it makes the ski spin with ease! The 2015 phantom is one of the best handling and most innovative skis of the year!! Phantoms are 100% vacume infused, offering the best resin to material ratio! Will post pricing, thanks[/QUOTE]
"The 2015 phantom is one of the best handling and most innovative skis of the year!! "
Is why I wanna try this sexxy beast out. That's the only thing that threw me off.
Nice write up. Good stuff. Hope to see ya soon at Wavedaze 2016?
Air blair cell
