08+ SJ Steering Adapter For More Throw
Has anyone used an adapter like Wamiltons offers on their 08+ SJ with any success?
https://www.wamiltons.com/index.php?main_page=product_info&cPath=74&products_id=913
Pros, Cons? (aside from the price being high)
It sounds pretty straight forward although I haven't been able to find any reviews on it. I broke my cable recently and I'm looking to see if now is a good time to make a change.
Here is my current steering setup
I've always made a bracket using the wave raider value hold down to relocate the cable and use 96-07 cable. Kinda like that one, but seeing this makes me kick myself for spending the time to fabricate something I could buy. Imo this is the single best mod to the 08+ sj. Instantly changes turning radius from crew cab dually to mini cooper. Add a good turn plate and your set.
Are you saying the turn plate currently on my ski is not a good one?
All this sounds positive. Going off the picture, I can not see how this bolts right up and works. Maybe I will call Wamiltons tomorrow and inquire. Correct me if I'm wrong though - aren't steering cables like $80? Why is the kit so pricey? That bracket is $120?
I've had my first ski for about a week so forgive my ignorance.
I'm in the same boat, I called Wamiltons and inquired about just the bracket and he wanted $125 , just for the bracket! @ScottS just made me a bracket for the 96-07 steering cable on the factory 08 handle pole. He cut the stock steering plate and tapped new holes to use straight bars. Works great!
Sorry doesn't look at the pic of your ski. Ada turn plate is good. Was really just speaking in general about the 08+ skis.
Keep in mind this is also a great mod for yamahas little step child the fx1. Which had very similar steering ratio to the 08+.
This is great! Thanks for the pics - that really makes is clear how it functions. I can't believe nobody else makes that bracket! I may try to make it myself. I wonder where I could get the indented U-strap? The rest looks fairly simple.
If you can find one reasonably priced, get it! Back in 09, I made my own and used a '95 oem cable, worked well. Figuring it out, making a sample, then the real thing, took me about 15 hours. Never again!
I am wondering the same thing the bracket doesn't look terribly hard to make but where to get the u-bracket?
